Thread: Signal analysis
Old 13-Feb-2011, 11:16 PM   #1
scott784
Signal analysis
I've got a HD 9095P UHF Yagi Style HDTV antenna with a HDP 269 12db amplifier. I'm getting good results with this antenna. However, I was curious about something.
One of my desired (out of town stations) is WAXN Channel 64 (Charlotte NC). I can get this station from one of the translators, 38 miles from my home but I cannot receive the main signal from the tower directly out of Charlotte. Interestingly enough, I did a rescan of my stations last night and the main (HD) broadcast out of Charlotte came in perfectly. However, now it is gone, again. So I am back to watching this station (WAXN) through their translator tower only (38 miles away versus the main tower at 61.5 miles away). I would prefer to receive the station through the main tower in Charlotte (on Vir. Channel 64-1) because that broadcast is in HD versus viewing the translator/repeater channel on Vir. Channel 64-7 which is in 480i only.
If you look on my tvfool report, you see that the translator station for WAXN is in yellow and the NM(db) are 17.2 Note: this is for the translator station which broadcasts in 480i only, which is located 38 miles away from my home.
However, my report also suggests that my outdoor antenna should be able to get WAXN (Virt Channel 64-1) from the main transmitter in Charlotte. See this highlighted in red/pink on my report.
Anyhow, I was just curious about this situation. I got this main station, once last night in HD but not again. The main transmitter shows 4.9 NM(db). That is not much to work with. However, I do have the preamp on my antenna. The entire length of the coax from outside to the livingroom is under 40 feet. There are no splitters or anything else that degrades the signal. Of course, I know the obvious day to day things that impact signal strength--especially when it gets weak.
But just a couple of questions about this situation. First, had I gone with a higher amplifier, is it logical to assume I would have received the main signal from this station out of Charlotte versus relying on the repeater signal tower only? Second, because I was able to receive the 'main' signal from Charlotte once on this station, and now I am back to not getting the main signal......is it reasonable to assume that I am losing about 5 NM(db) on all my channels? Maybe, any station listed (for anyone) at around 5 NM(db) is just too little to realistically work with? Thanks for any replies.
Again, I was just curious about this matter.
http://www.tvfool.com/?option=com_wr...e07c93c07c6564
scott784 is offline   Reply With Quote
