Old 15-Mar-2020, 4:11 AM   #8
shoman94
As noted by Tim, that was for the old DB4 which was discontinued many years ago.
Get the tech data sheet for the DB4e off the website, print out the horizontal polar pattern, draw a new curve 2-3 dB inside the existing curve (on the "hot" side), then mirror that to the other side. You'll be right in the ballpark as to what would be expected.
So I will likely lose maybe 2-3 db on the front end on each of the 4 patterns?
Also what do you think would happen if only one reflector was removed?
