Old 13-Feb-2011, 10:00 PM   #2
Tower Guy
Originally Posted by carbon rod View Post
2. Assuming I need a two-antenna setup, what's the best way to join the Chicago signal to the Milwaukee signal? Is there something that will allow me to join them into the same coax line, or would I be better off having a “milwaukee” DVR and a “chicago” DVR and just sharing material via computer network?
Don't try to combine them. Use an A/B switch to switch between them, or get an external tuner/DVR for the second antenna. For instance, if you had a Channel Master CM-7000PAL connected in your preferred direction you could DVR those stations and watch the other city live.
A two tuner HD Homerun can also deal with two antennas.
