Just got off the roof, finished changing out The Balun. Since the temps have moderated into the 50-60'S during the day, I once again only get 5 channels. There was NO change with the balun replacement. I also noticed a bad "F" connector on the down feed and replaced that as well! Might be time to replace the RCA pre amp as a just to be sure its good?
Tower Guy mentioned lowering the antenna to find the "sweet spot" what is the distance between the layers? Am I looking at 6 inches or 3 feet to find the "sweet" spot? It might be easier to go up 6-8 inches with a re location of my chimney mounts rather than going down 20-25 inches!
Thanks
Olnick
