Old 11-Mar-2020, 8:08 PM   #40
jp2code
Ctrl+Alt+Delete
jp2code's Avatar
Originally Posted by MikeBear View Post
What does: "I have to punch it in manually" mean? Are you saying if you punch in say 7.1 on your remote, it then comes in and works?
If so, then what does: "It no longer appears" mean? No longer appears WHERE, or on what?
What brand and model number of tv set, or tuner device are you using? If you have more than one, does this happen on all of them?
By the way, TvFool hasn't updated in a very long time, it's no longer accurate. Here's a RabbitEars report for your area: https://www.rabbitears.info/searchma...study_id=68840
That means the channel search doesn't find it, and I have to push in 7.1 on the remote to see a bunch of static.
EDIT: Actually, it isn't static. People on here are too literal. The TV says there is no signal.
~Joe
Avoid Sears Home Improvement!
jp2code is offline   Reply With Quote
