If I lived in your location I’d try a DB-4e UHF only aimed at Syracuse and the VHF only Stellar labs antenna aimed at Binghamton.
I like the DB-4e because the UHF stations in Syracuse are spread too far apart for an 8 bay or 91XG.
The best location for the UHF antenna and the VHF antenna will probably be two separate locations.
You will want a preamp. The TVPRAMP series has two inputs, one for UHF and one for VHF. That properly combines the two antennas with no worry as to the length of cable from each antenna to the preamp.
