OK, enough is enough! John, if you are going to give practical advice, then you need to check the path profiles. Cosmo is facing a very challenging situation, as he has to rely on scattering from tall terrain obstructions in the way. Going up to 100 feet is not going to materially change anything.
Cosmo, I seriously doubt you will be able to get all the major networks. ABC will definitely be a no go, and the translator that would bring you Fox will be iffy. John's recommendations are probably the best you can do under the circumstances, but realize the following:
The 7084P will get you NBC and the independent reliably, and CBS with drop outs. The 91XG will be for PBS and Fox, and reception will have drop outs. At 20 feet, 40 feet, or 100 feet, the answer will still be the same. It's up to you if you want to spend that kind of money for results that will be less than you hoped for.
