Old 23-Feb-2010, 12:23 AM   #4
mtownsend
Your tvfool report tells you exactly which VHF and UHF stations are in your area. If you take a look at the rectangular graph at the bottom of your report, it shows how all the channels are occupied. The horizontal axis is the channel number (2-69) and the vertical axis is the relative signal strength.
Your report is showing no channels in the low-VHF band, a couple of channels (WJBK and CBET) in high-VHF, and the rest in UHF. In order to get WJBK and CBET, you'll need to make sure your antenna setup includes high VHF capabilities (either using a combo antenna or combining separate VHF/UHF antennas).
The HD769xP family of antennas is designed for channels 7-69, which covers all the channels in your area. That is why they top the list of recommended antennas for your situation.
