Old 10-Jan-2020, 9:16 PM   #18
Tim
Originally Posted by corvairbob View Post
yep that is the pole i have in my side yard looking out to the grand rapids area. you got it good. thanks
If power line noise is causing interference to TV reception, call the power company. They have to meet certain FCC regulations and will come out and investigate. It often saves them money in the long run because it points to problems that need be to repaired such as loose hardware, corrosion, defective insulators, etc. Most power line noise is caused by arcing and arcing in a power system indicates something that they want to repair. They have some standard gear and some special equipment that will help them to quickly diagnose any issues.
