Old 10-Jan-2020, 8:02 PM   #17
Do either of your antennas have preamps? If so you could remove the power from the power supply to the unused antenna(s).
I assume that you are trying to combine antennas aimed in different directions and a simple combiner does not work. Can you provide a rabbitears.info report for your location that shows which antennas need combining?
Thanks for jogging my memory TG...
In the past I've thought about using line amps as RF switches. Simply power up the amp to pass signal, power down to block it.
Likely the most practical option for a consumer grade off-the-shelf solution. Cost and availability of parts would be better than an industrial or commercial product.
