Old 9-Jan-2020, 6:17 PM   #2
I'm not aware of an 'off the shelf' retail solution... Hopefully someone else does. I think you'll need to have some DIY skills with hardware and software. Doing a quick search online, I came up with this;
https://www.jfwindustries.com/produc...oaxial-switch/
I would expect an Arduino with Ethernet or Raspberry Pi could be used to interface via a web devise. I would investigate the Arduino first because it will directly support TTL (0 to 5V) signal levels whereas the RPi uses 3.3V and would need a level converter in-between it and the RF switch.
