You want no reflector to pick up Maryland PBS (real 28) off the back of the antenna.
You could buy the 2V on Amazon and drill out the two rivets that hold the reflector to the frame.
Or you can add the VHF dipole kit to your existing DB-2. If the reception of 28 is sketchy you can see if the reflector on your existing antenna can be removed.
