Old 6-Dec-2019, 11:45 PM   #12
Originally Posted by BigHenry View Post
I have a Channel Master CM-5020 antenna which connects to the balun and then directly to the tv. The antenna is only about 18 months old. In that short time I have had to replace the built-in balun with a CM-94444. It looks like that balun too is failing because I have the same symptoms of intermittent, random loss of channels.
Here is my TVFool report:
http://www.tvfool.com/?option=com_wr...9038f3360d6a26
Hello, BigHenry; welcome to the forum.
Thank you for the signal report. Here is a report based on your exact address instead of your zip code from rabbitears.info:
https://www.rabbitears.info/searchma...study_id=33265
This image is an extract from that report:
What happened to the original balun, did it break or did it just not perform the way you thought it should?
