Old 5-Dec-2019, 11:40 PM   #1
BigHenry
300 ohm wire, max length??
Hello,
I have a Channel Master CM-5020 antenna which connects to the balun and then directly to the tv. The antenna is only about 18 months old. In that short time I have had to replace the built-in balun with a CM-94444. It looks like that balun too is failing because I have the same symptoms of intermittent, random loss of channels.
My question is, can I run some 300 ohm wire from the antenna to inside the house and then attach to the balun? I really hate going up on the roof to replace baluns BTW I'd estimate the wire run would need to be around 50 ft...
Here is my TVFool report:
http://www.tvfool.com/?option=com_wr...9038f3360d6a26
Thanks for your help,
Don Verbeck
BigHenry is offline   Reply With Quote
