Old 16-Nov-2019, 8:23 PM   #9
Originally Posted by tuktuk View Post
Great, thank you. I was not aware they had an app like that.
So, I assume you are suggesting not order amp/booster with the antenna, i probably don't need it right with 50-60ft of cable length, right?
Thanks.
Yes, try it without an amp first. OTAFAN is correct, you shouldn't need a preamp because your signals are strong enough to cause overload if you add the antenna gain and preamp gain to the Noise Margin figures in your TVFool report.
I got curious about the Hauppauge tuner so I ordered a 955Q. The previous Hauppauge USB stick didn't work very well for me in 2013, but this time the installation was OK.
