So, I assume you are suggesting not order amp/booster with the antenna, i probably don't need it right with 50-60ft of cable length, right?
Download (if you have not already) the Hauppauge Digital Signal Monitor app and run diagnostics to see if your SNR is good, as described above by rabbit73. My guess from his analysis is that you probably won't need a preamp, more like adjusting your antenna for maximum signal reception. Usually in a strong signal area where you live (mine is similar here in LA/OC SOCAL), a preamp is not needed.
You're getting close to resolving your issues, tuktuk. Probably just some more keyboard and leg work. (Remember SAFETY FIRST when up near or on your roof!)
Please keep the forum posted. I would be interested in how it turns out for you. Thanks again.....
