Old 9-Nov-2019, 7:02 PM   #5
Tower Guy
In your case I’d try an Antennas Direct 2MAX and couple it to your existing 751 using your preamp as a combiner. The 2MAX is bidirectional and should get most of your UHF stations well. I believe that your ABC is WLOS on VHF. If so, I’d aim your 751 at WLOS. WLOS doesn’t show on your rabbitears report because it’s further than 60 miles away.
The use of two antennas using the preamp as a combiner is a unique solution that will combine UHF and VHF antennas with no compromises. The VHF ability if the 2MAX will be tuned out by a filter in the preamp. The UHF ability of the 751 will be eliminated by the preamp.
