Old 9-Nov-2019, 8:45 AM   #3
OTAFAN
Originally Posted by 8bit View Post
I can currently get ABC, CBS, NBC & Fox but Fox and especially CBS would break up often. I'm interested in only these major networks.
My question is, should I go higher up with an extension pole with my current antenna or purchase a good antenna like a Winegard HD7698P Platinum Series.
Also, is it possible to install two antenna facing different directions but combine them so a motor is not necessary? With the correction position I can get all channels but CBS still suffers. I'm just trying to cover all the bases. Please suggest an antenna or antennas. I would greatly appreciate the help!
Hello 8bit:
According to the zip code you provided in your TV Fool report, the rabbitears.info report shows better Post-Repack reception for that area. Obviously, you mentioned you were in a bit of a hole with surrounding tall trees which makes reception more challenging; although you seem to be getting most of the stations you desire. Here's the report for your zip code, but GroundUrMast's advice is wise. (Your rabbitears report takes a bit under 20 seconds to load).
https://www.rabbitears.info/search.p...=dBm&height=12
Also, here's a link for combining two RCA ANT751R antennas that might be helpful if you decide to go that way. A bit expensive, but you might save some money by just buying another ANT751R and related supplies separately.
https://www.dennystvantennare.com/bi...bles-in-stock/
I'm sure there are other's here who could help you achieve your goals if they decide to chime in.
All the best.....
