Old 7-Nov-2019, 10:51 PM   #1
devidog
preamp+ distribution amp
I have a mast mounted preamp and reception is fine in the LR. Bedrooms are a little sketchy at times. Thinking about adding a distribution amp. Any thing I should beware of? Should the amp go after the splitter or amp everything then pull all three off of the splitter. The way it is now, I have the inserter on the lead from the antenna right into the splitter. Thanks in advance.
devidog is offline   Reply With Quote
