Old 4-Nov-2019, 9:06 PM   #15
Tower Guy
Hi eggman.
What material would you like to use to build your channel 6 yagi?
I did a design that uses 3/4” hardline from a CATV scrap pile for the elements. I’ll send you the dimensions if you have access to that material.
I have also built a bidirectional V beam from simple wire. A full rhombic is another option.
In hilly areas such as yours the location of the antenna makes a significant difference. I have seen antennas in the side yard on a 10’ pole work better than the roof.
Goo goo gachoo.
