Thank you everyone for your thoughts. I too was thinking I had pretty much maxed out my results currently.
The 7777 pre amp I had was the single input. My main consideration was whether this unit with the extended gain may enable a little more stability on some channels but it sounds like the gain would be minimal.
I don't see any issues here with the re-pack as there is only the one channel moving to RF20 that may cause some disruption with OMNI. All others from Michigan moving will be slotted into open RF's.
