Old 18-Oct-2019, 1:11 PM   #12
BrooklinOTA
Thank you for the TVFool report. Here is a rabbitears.info report based on my estimate of your location. It should have a more accurate list of channels.
https://www.rabbitears.info/searchma...study_id=20077
You can do your own report here. You might need to use coordinates.
Extract from rabbitears.info report:
It is not clear to me where you think that 2.6 dB loss is coming from.
Is it because there is a long length of coax between the antenna and the input of the RCA preamp, or some other reason?
My quess is that the RCA preamp causes an initial 2.6db of signal loss as the signal from the antenna goes into the unit. Is that accurate?
BrooklinOTA is offline   Reply With Quote
