Thread: Best Rv antenna
Old 7-Oct-2019, 4:57 PM   #15
Yes, we came out with the C2V-RV earlier this summer. It's intended to retrofit onto an existing Winegard-type crank-up RV mount.
If there were a clearance problem could they or just one side be shortened without sacrificing much high VHF?
The dipoles may, if necessary, be folded down for traveling which would, of course, require a trip up to the roof.. I would not recommend shortening them haphazardly.
Both the PA18 and the Juice operate on 12-15 volt DC power sources. Our supplied power supplies for both are regulated at 12 volts. The existing Wingard power inserter works fine for this purpose.
