Old 25-Sep-2019, 6:31 PM   #9
Originally Posted by freetvplease View Post
Update on my friends system. I used my coax tester (which I should have done to begin with) and found out that the connector on his exterior box was installed incorrectly. I cut it off and replaced it correctly and then all his 4 tv's had 80+% signal strength. So, I didn't have to use the HDA-100 after all. Lesson learned is never skip any steps.
Thanks for the update; good detective work.
