WMOW Crandon, WI
I'm hoping someone can help with the problem relating to this station. WMOW (satellite of WAOW Wausau) does not show anywhere when searching a location by address. The only place it is visible is when searching by callsign; however, this is even a problem. When searching by call sign, the map is positioned in the middle of the Atlantic Ocean (off the coast of Africa) and you need to manually move the map to northern Wisconsin.
Thank you in advance to whomever reviews this problem.
