Old 13-Sep-2019, 7:39 PM   #22
ssharnick
This is an image of your report:
This is a link to a report by rabbitears.info which should have a more accurate list of channels:
https://www.rabbitears.info/searchma...&study_id=6125
You can use the Stacker for UHF and VHF or you can add a VHF antenna to your present UHF antenna and combine the two with a UVSJ UHF-VHF Separator-Joiner.
https://www.newark.com/stellar-labs/...vhf/dp/48Y8141
https://store.antennasdirect.com/antenna-combiner.html
If I were to add a VHF antenna to my current 8 bay, would it be OK to mount it below the 8 bay on the mast? Does it matter if it's below or above the UHF that's already up there?
Thanks!!
ssharnick is offline   Reply With Quote
