Thank you rabbit73! You did give me all the details I needed!
I am amazed that I get 24.1 as it is in the same catagory as 25.1 "bad" signal!! I can swing the ant approx 10 deg mag. either side of 161 deg mag and still get 24.1? If they are coming from the same tower I should be able to get 25.1 when the dust finally settles. (I hope).
That is the point when the cord gets cut once and for all!!!
Olnick
