Old 26-Aug-2019, 4:16 PM   #14
Tower Guy
The stacker is a good antenna, but it is not optimum for you. Yes, you need to add VHF ability to your existing UHF antenna, but you need your VHF and UHF antennas aimed in different directions. Consider adding a ANT 751 to your existing antenna using a UVSJ. Aim the VHF at WTNH. You’d ignore the UHF ability if the ‘751. Then you can optimize the aiming of your UHF antenna for the other stations you want.
