Old 16-Aug-2019, 8:59 PM   #2
jrgagne99
You have a nice report. All the major networks are strong and on UHF. You might be able to get away with a 4-bay such as the HDB4x, DB4e, or Clearstream 2, aimed at 217-degrees. If you don't care too much about size, go with a 8-bay or Clearstream-4 for better chance of reception right out of the gate. You should check the rabbitears report first thouh, to make sure nothing is moving to VHF-hi. If so, and depending on signal strength, you might need a stronger VHF rig, such as a 2475.
Also, and it kind of goes without saying, but mount it outside, high, and with a clear view (no trees) for best chance of reception.
