Old 15-Aug-2019, 1:49 PM   #3
Originally Posted by Dagwood
Hi Rabbit, thanks for the help. He has a small antenna that someone gave him, and so far all he did was walk around outside with it trying to pick up anything -- with no luck.
I told him he will probably need a big roof antenna like I have.
What channel? I don't know, whatever he can pick up.
Yes he has trees, but mostly is down in a valley similar to me -- only worse.
Thank you for the additional information.
I looked at the satellite view. You are right; it does look worse than your location. He is surrounded by trees that will block TV signals:
and he is down a hill:
Even with a big antenna as high as he can get it, he will not be able to get much.
