TV Antennas and Reception
Most all Tv reception situations have variables. Here are some of yours. . Getting reception down to WSB 39 ABC with a minus -3.7 NM(dB) signal strength is a stretch. Will need to turn the antenna to the left and right to find the strongest signal. If WSB 39 ABC is not receivable there is WSB 46 ABC at 143 magnetic compass and may need to turn the antenna some in that direction to receive it with out losing the weaker channels at Atlanta. It's a balancing act. . WPXA-DT 51 ION and WATC-DT 41 are off axis with the front of the Tv antenna and this reduces reception. In this situation it's Ok because the signals are strong , The reduction in signal strengths will make them more like the signal strengths of the other channels.
