Thanks OTAFAN and GroundUrMast for the replies. The area is indeed hilly, but I'm situated near the top of one.
I have a directional attic antenna, think its an RCA ANT751R, and while I don't have an attic here, I figured I might use it to test. I pointed it directly downward, set it in a window sill, and put a piece of aluminum foil across it. This setup is getting me perfect reception of all of the network stations.
Given the good results with my test setup, do you have any indoor antenna recommendations? Would I still be best going with something like the 2Max or Flex, or might something less expensive do the job?
Thanks again for the help!
