Old 6-Aug-2019, 9:13 PM   #8
w0en
If you are receiving virtual channels 9.1, 9.2 & 9.3 with out difficulty, the likely problem is one of the following:
1. The broadcaster is not currently transmitting that sub-channel or they are sending blank data on that sub-channel. A polite call to the station engineering team may answer the question.
2. There is an issue with your TV. A re-scan may solve the problem. (see you user manual).
KMSP 9 has two frequencies. 9-1, 9-2, & 9-3 are on UHF 29. 9-4 and 9-5 are on RF channel 9 on hi-VHF. 9-1 & 9-5 are duplicates of the main channel. Buzzer would need to have a hi VHF antenna to receive it which I don't believe the Mohu antenna covers. They did this after the transition as RF9 didn't cover some areas well.
w0en is offline   Reply With Quote
