Old 31-Jul-2019, 3:44 PM   #3
Your TV Fool report indicates that your antenna needs to be located so it can have a clear view to the west. If there are neighboring buildings or trees blocking that view you can expect problems with reception.
I've come across 'energy efficient window glass that blocks a substantial amount of radio/TV/WiFi signals. Just because you can see through a window does not mean you can get acceptable reception through it. If you have exhausted every possible mounting location with your existing antenna, I'd try a 2 or even 4 bay design such as the Antennas Direct ClearStream 2 or 4 Max... Though you'll want to carefully consider the size of these antennas vs. your available space before ordering.
