Old 30-Jul-2019, 1:42 AM   #7
OTAFAN
Hey Mike:
Here's your rabbitears.info report (takes about 20 seconds to load). You can actually go the searches there and put in your address to nail down reception at your specific location.
https://www.rabbitears.info/search.p...=dBm&height=25
Good advice above regarding amps. Looks like you have both High VHF (1) and UHF channels LOS and 1 & 2 Edge. Perhaps an RCA 751 or similar could work depending on any obstructions you might have, as your mentioned. You might want to think about a good antenna instead of the amps right now. Get up on your roof (safety first!) and find the spot which gives you the best reception.
Just my two cents worth.....
