So the ground block for the coax should;
a.) Not be up by the antenna or in the house?
b.) Should not be in series with the the mast ground wire ?
What that means for me is running more coax from the antenna down near the grounding rod and where my cable TV input already has a ground block. I had always thought the best way was to put the coax directly into the house from the antenna and keep it short as possible.
