Old 22-Jul-2019, 6:52 PM   #2
Tim
Originally Posted by John951 View Post
Hi,
Grounding is also going to be a bit of an issue too because my main power will be on the opposite side of the house getting to it would add about hundred foot of RG6. So thoughts on driving a ground rod?
http://www.tvfool.com/?option=com_wr...90383fca9b9c9a
You can install a 5/8" x 8' ground rod directly below your antenna. Then you will need to connect the new ground rod to the ground rod at your service entrance using #4 solid copper wire. The new ground rod should be driven a few inches below the soil surface and the copper ground wire should be buried a few inches or more to protect it from damage.
Do not neglect the part about connecting the new ground rod to your service entrance ground. That insures that the two ground rods maintain the same electric potential and prevents some serious issues from occurring with voltage differentials that could cause significant problems.
