					Originally Posted by  GroundUrMast
				Looking at the post repack info on rabbitears.info, I don't see much reason to use an all channel design. I'd opt for a Winegard HD7698P and an Antennas Direct 'Juice' preamp. If the tower puts the antenna above the trees you should do well.
I'd aim toward Atlanta. Reception from other directions would likely suffer from the effect of distance and blocking terrain.
 Thank you GroundUrMast,
 We did well years ago with much less height so this should be much better.
Best Regards, Tony
