Old 15-Jul-2019, 3:08 PM   #4
Chevy power
Thanks for the reply. I also sent an email to wviz. They confirmed what you guys have said. Here is their reply.
Matt,
Thank you for your interest in WVIZ.
We have indeed made a change to our signal. Temporarily we are on an auxiliary antenna while we make changes to our main antenna.
We are changing channels as a result of the FCC spectrum auction which reassigned half of the current TV channels to wireless broadband. This requires over 1000 TV stations to change channels. We are one of 11 stations affected in the Cleveland area.
For a while we will be on the backup antenna and occasionally going off the air completely as men and equipment are moved up and down our tower.
On August 2 we will move to Ch 35, which may require you to do a channel rescan on your TV.
We expect to compete all work around the middle of August and return to operating on our main antenna.
After that move we will have a stronger signal than our previous one, so your reception should be better than it was previously.
We appreciate your patience during this period.
Chevy power is offline   Reply With Quote
