Old 11-Jul-2019, 2:28 AM   #26
Tim
Originally Posted by Insaneoctane View Post
Also struggling with the standard chimney mounting straps. My chimney is stucco and I'm worried that as I cinch the straps down they will crumble or break the stucco. Seems like they need to offer some slightly compliant padding for the corners for stucco?
Many years ago I used some 6 inch lengths of 1/16" thick pieces of 1-1/2" aluminum angle on the corners of of a stucco chimney and it worked fine. You can find it in your local big box home improvement store. A four foot section will give you eight 6 inch pieces.
