Old 9-Jul-2019, 9:45 PM   #22
JoeAZ
Originally Posted by Insaneoctane View Post
Hopefully I will decide on the antenna soon. One thing that has me slowed down right now is that Im now considering rooftop vs attic (where I started this thread) and the grounding requirements are making the installation job much much more complicated. I'm starting to consider maybe just grounding the mast and coax and possibly skipping the 6 gauge to breaker as that is an entire new level of PIA....
Also struggling with the standard chimney mounting straps. My chimney is stucco and I'm worried that as I cinch the straps down they will crumble or break the stucco. Seems like they need to offer some slightly compliant padding for the corners for stucco?
I tried and tried to attach photos of a stucco mounted antenna
I recently installed but I keep getting a message that I'm over
the 500 mb limit. In any event, I would suggest you go into your attic
and survey the inside of the stucco chimney. You probably have 2x4's
at the four corners. If you cut another 2x4 about 2-3 feet long and
put it on the inside of the chimney, you can use a "Y" style mount.
One side of the mount will go into the corner 2x4's and the other side
of the mount will screw into the 2x4 you placed behind the stucco
in the attic. Hope this makes sense. Grounding the mast and cable,
while not perfect is certainly better than nothing at all.
