Old 8-Jul-2019, 8:41 AM   #11
OTAFAN
I think JoeAZ meant your TV signal meter on the television set in your house. Either that, or a small hand held TV you could use up on the roof to see where your best signal(s) strength location is.
If you use the first method, you would need to have a family member or friend down inside watching your TV signal meter, while you moved the roof top antenna around to figure out the optimal reception on the channels you're interested in. (You could do this solo, but given your location you'll be up and down your ladder A LOT).
He might have another idea about this, but I know from a few of his previous postings regarding this issue, he mentioned the above two methods.
