Zip codes usually cover larger areas than an exact address. You did the right thing to narrow down your reception quality.
JoeAZ knows your area and he's another experienced Tech on this forum. I would go with his recommendations too.
If rabbit73 will chime in on this thread, he could give you some visual aids that might help you achieve your goals. You could even PM him to keep your address secure, and he would be able to specify exactly what you need.
I'm not a Tech, but have learned so much on TV Fool from all these good chaps, that I try to pass on what I know works at my location here in SOCAL LA/OC. But to answer your question, I would say if you don't need low VHF real channels 2-6 and just want high VHF channels 7-13, then yes, you could get by with VHF high. But you do have a few major LA stations that broadcast on UHF, but show virtual VHF channels. So, it all depends on what you really want or need.
Let us know how it all works out for you. Take care, Insaneoctane…..
Reason: additional
