Old 10-Feb-2011, 10:34 PM   #12
Originally Posted by llzel View Post
Tower, yes that's the omini-directional antenna I have in the attic.
The signal is worse when I don't use the inline amplifier.
The inlne devive is not an amplifier, it is a power inserter.
The signal is worse when you unplug the amplifier because there is no amplifier bypass in the antenna. The unpowered amplifier causes more distortion than the powered amplifier. Either way it can't work that close to the TV stations.
Try this instead: http://www.target.com/GE-Omni-TV-Antenna/dp/B000EIMKYC
