Old 14-Jun-2019, 1:50 PM   #34
jrgagne99
Originally Posted by RMinNJ View Post
a.) So if I were to put this little antenna higher on the eave it may be better?
Not necessarily. I encountered a similar situation before finding my eventual antenna solution. I had been hunting all over the roof for reception of a particular channel that my report said should be there. I could not find it on the roof. One day by dumb luck, I found a hot spot for it right in front of my garage door at 5 ft AGL. Moving the antenna left/right or up/down by 2 or more feet would totally lose the signal. One of the senior forum members called it a "ground bounce" as I recall. Constructive interference from the signal arriving from two or more different angles at precisely the same time.
Or would that introduce more noise from other signals .
More noise from other signals (co-channel or adjacent channel) is possible, but I think it is more likely that you will no longer be in an area of constructive interference due to the signal refracting around obstacles in the signal path.
b.) Weather and atmosphere give the illusion that things are working well?
Yes, that's a tricky one too. For marginal signals, I think it takes 1-2 weeks of regular observations over varied weather conditions before you can be confident in the validity of your antenna location.
