I think that the HD7694P might not be as good on VHF band as the stellar labs you have which doesn't seem to have much spare signal strength. The HD798P would be more likely to work along the lines of the stellar labs but I realize it is a much larger or at least longer antenna .
Another option would be the larger stellar lab VHF antenna the 30-2476 that might not need amplification and use a UVSJ and a separate UHF antenna, however the db loss of the UVSJ itself would likely put you back at or below the performance of the 30-2475.
