Tv Antennas and Reception
Replace ALL the coax cables with new RG-6 . And use a coax ground block to ground the new RG-6 with. . There is no reason to be using any type or kind of preamplifier , distribution amplifier , line amplifier or any other type or kind of antenna system amplifier. The Tv transmissions are so strong they will blast a hole through 6 inch steal plate. . If tv transmissions are not getting to the basement then the basement is 20 floors below ground or the old coax cable has a nail through it , also do not reinstall that 32 way splitter.
