4-Jun-2019, 3:18 PM
#30
Originally Posted by jrgagne99
..........you might consider the RCA ANT-751 which will have more VHF-high gain, and probably adequate UHF, given your strong, LOS signals. Go for an outdoor mount, with a clear view (no trees). If you have trees, it is a bit more dicey, and a larger antenna such as the 7694P may be required.
So in summary, a small-ish UHF/VHF-hi combo antenna should work. No 8200U and no CM-7777.
I agree! You need more gain on VHF.
