Old 24-May-2019, 9:19 PM   #111
jrgagne99
I have the opportunity to borrow my neighbor's 60-ft man-lift again this weekend to service my tree-mounted antenna array. This may be the last time I get to do any maintenance up there for several years. I'm planning to re-aim and re-secure my 30-2476 VHF antenna which has been blown off by 45-degrees. I was also planning on replacing some my non-UV-stabilized zip ties with UV-stabilized ones, and putting dielectric grease in the barrel connectors.
My questions are what kind of dielectric grease should I use, and is there anything else I should do while I'm up there, considering I probably wont have access again for several years?
Thanks in advance!
