Old 15-May-2019, 4:56 PM   #3
rickbb
You have one of the better antennas, (gain wise anyway), that you can get. It's only negative in your situation, is that is highly directional and your towers are spread around 180 degrees.
If you have a rotor to move it in the direction of the tower you want already then you are probably getting about all you are going to.
The only other options are;
1. like ADtech said is to ask about a specific station you want so people can think on that scenario.
2. Go into experimental mode and start making your own system(s). If you don't mind having several different antennas and doing trial and error at combining them when aimed in different directions then you may, (and that's all it is, MAY), get more channels.
